ac fuse
Old 07-01-2011, 07:40 PM
351wfox
351wfox's Avatar
Default ac fuse
sup guys new on here, have an 82 gt 351w etc. My question is my fuse keeps poppin for my ac when i turn the switch on and have no clue why. Live in phx az my only car and have a pregnant girlfriend so need to solve this quick.
thanks
351wfox is offline
Old 07-03-2011, 06:24 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Could be a bad compressor clutch. You could have a wire shorted somewhere. Unplug the clutch and turn it on, see if it still blows the fuse.
PRO50SC is offline
Old 07-04-2011, 06:18 PM
351wfox
351wfox's Avatar
clutch works hooked a battery too it and started the car and it blows cold *** air. I could un hook it and try the fuse again.
351wfox is offline
Old 07-04-2011, 09:56 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
then your short is somewhere in between. now you'll have to start tracing wires. check the a/c relay.
PRO50SC is offline
Old 07-05-2011, 11:16 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
that means jack.....current draw is what you are looking at, I've had compressor clutches that work that have higher then recommended current draw due to excessive resistance in the windings on the coil circuit of the clutch, you'd have to check the resistance of the windings and compare to spec to properly rule that out.
mjr46 is offline
jwog666
12-27-2021 08:09 PM
daytooday
09-20-2015 10:55 AM
wenmill
09-11-2015 07:07 AM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: ac fuse
