cobra intake install questions w/ pictures
Old 09-03-2011, 08:06 PM
marlyman
marlyman's Avatar
Default cobra intake install questions w/ pictures
so i threw this cobra intake manifold on my 306 i built an its running ruff think i didnt plug the vacuums in correctly so i was wondering what goes where this intake is bit different than the stock one like the spot where the charcoal filter plugged into isnt there and the throttle body spacer isnt there but anyways my questions are for picture #1 : what goes here? ( ive had my line to the charcoal filter plugged in to it ) and for picture # 2 : is this supposed to be plugged off? ( i took the capp off my stock intake an put it on cuz on the stock intake it was cappd off an on opposite side was where the charcoal filter connected..) thanks for any input hella appreciate the help! Image 1 = Image 2 =
This the car
marlyman is offline
Old 09-03-2011, 08:57 PM
sjd3021
sjd3021's Avatar
your right about pic1- pic 2 is for your pcv, on my intake the vacuum hose is connected to that nipple at the end of the hose there is a tee, one side goes to the pcv, the other side goes to the bottom of the cross section of the upper intake
sjd3021 is offline
Old 09-03-2011, 09:04 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
lets put it this way...vacuum is vacuum.... Only a few items need to be hooked up in a specific way
projectresto83 is offline
Old 09-04-2011, 12:30 AM
marlyman
marlyman's Avatar
Vacuum is Vacuum hah thanks that helps a lot...
Ahem so that plug that i have capped off needs to connect to the pcv an ? wats the cross section? screw trying to explain think pictures make it easier an more simple...And so is the cross section the plug that in picture 1 has the green arrow pointing to it? of course on the cobra intake there is not a double outlet plug it is just single one tube/connector an picture #2 is on a stock intake but is same spot on the cobra intake...pretty sure im makin sense of it all but jus wanna make sure...i appreciate all the input seriously i knew i had sum **** hooked up funny...thanks again oh an for everybody vacuum is vacuum thank you. lol
Picture 1 :
Picture 2 :
marlyman is offline
Old 09-04-2011, 09:42 AM
projectresto83
M.A.D. Motorsports
The thing is about these intakes is that (explorers mainly) the vacuum ports are slightly different from year to year.
All that is needed to be hooked up is the: Source, FPR, PCV, Charcoal canister, Emissions block, then the MAP sensor if your speed density..
Do you have a flat pic of the underside of your intake so we can make a diagram for you? For some reason I have having a hard time finding such a simple pic.
Old 09-04-2011, 10:46 AM
ALMOST STOCK
ALMOST STOCK's Avatar
marlyman you have a PM
ALMOST STOCK is offline
Old 09-05-2011, 02:22 AM
marlyman
marlyman's Avatar
whats the PM stand for? o an i got the vacuum lines from the upper intake correct now ..runs better but my idle still a bit ruff i think its something with my timing got new spark plug wires an redid my timing an when i have the plug that allows the computer to advance the timing unpluged the idle stays good an doesnt really bounce when i stay at idle..the plug im talking about connects at the distributor i forget the name of it but i heard its ok to run without it but i noticed major loss of power with it unplugged an at the right timing set SO i jus advanced my timing to get my power back is that ok to daily drive with? an if my idle bounces/drops to like 600rpm when the plug is in does that mean i need a new/dif computer?
marlyman is offline
Old 09-05-2011, 08:38 AM
projectresto83
M.A.D. Motorsports
PM= private messages.....
Did you pull your distributor when you swapped your intake? The plug is called the spout connector. If it worked before you swapped then it should work now. That means you did something wrong. You need to figure that out then do a base idle reset as well most likely.
Old 09-05-2011, 09:52 AM
ALMOST STOCK
Disregard the Personal Message (PM) then .
FivePointToTheOh
03-09-2020 10:26 PM
daltron
04-28-2016 08:10 PM
treesloth
09-28-2015 07:03 AM
yourmom6990
09-14-2015 10:52 PM
robjh22
Suspension
09-08-2015 12:47 PM
Quick Reply: cobra intake install questions w/ pictures
