idle problems
Old 09-06-2011, 03:36 PM
tito88
tito88's Avatar
Default idle problems
i don't know whats wrong with my 88 gt 5.0 the motor is 86 though. When i start the car its fine but as soon as i give the car gas the check engine light turns on and when i let off the gas it has a very bad idle it goes up and down for a while just wanting to turn off and sometimes it does but when it doesn't it idle?s rough till the check engine light turns off and then it idle normal again till i give it gas again. I already changed the idle air control valve. thanks hopefully someone could help me
tito88 is offline
Old 09-07-2011, 05:21 AM
wizwrath
wizwrath's Avatar
Did you check your TPS sensor? Check for vac leaks too. Also check your MAF sensor (also clean up the sensor sensing wires too, use the MAF air cleaner).
wizwrath is offline
Old 09-07-2011, 10:18 AM
tito88
tito88's Avatar
ya i changed changed tps sensor. i will check out the maf today but how do i check for vaccum leaks?
tito88 is offline
Old 09-07-2011, 11:07 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
lol..slapping parts and you have a CEL on?? RUN a koeo/koer test and see what codes exist, do this before doing anything else , otherwise you're throwing dats in a dark room
mjr46 is offline
Old 09-07-2011, 03:42 PM
tito88
tito88's Avatar
how do i do that test koeo/koer test?
tito88 is offline
Old 09-09-2011, 01:38 AM
wizwrath
wizwrath's Avatar
OMG, I didnt see that you have CEL going on, dude, thats the first thing you check on first then run diagnostics, then go through the list and eliminate/fix them. There is methods to run the KOEO tests. If you cant find the procedure here, go to:
SBFtech.com
And do reading there, if you cant still find it look up Joel.
Dont give up, keep at it........
wizwrath is offline
2007CalSpec
12-13-2020 11:42 AM
2007StangV6
01-28-2016 06:09 PM
96stang3.8
09-10-2015 06:42 AM
94stangnewbe
V6 General Discussion
09-07-2015 07:39 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: idle problems
