tach ????????
Old 12-04-2011, 06:12 AM
blackhawkkid308
blackhawkkid308's Avatar
Default tach ????????
when we bought the 92 lx convertible the fuel gauge didn't work and after troubleshooting the problem i replaced the little plug in circuit board on the back of the instrument cluster called the instrument cluster voltage regulator. everything has been dandy for a few weeks, then yesterday while we were riding around the tach jumped up at idle to 2800 and stayed there. it will go up above that but not below. after riding a while longer it started to fluctuate some and dropped back to normal, it has done this several times and now stays up. when you turn the key on to run where the tach drops to zero it starts out at 600. does anybody have any ideas?
bhk308
blackhawkkid308 is offline
Old 12-04-2011, 08:17 AM
eb2gt
eb2gt's Avatar
check connection at coil. By this check for corrsion or loose terminal end etc.
eb2gt is offline
Old 12-04-2011, 10:58 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
The tach in the cluster is the issue. Most fox tachs after all these years become inaccurate..some worse than others.
projectresto83 is offline
bryan616fl
01-25-2019 09:07 PM
96stang3.8
09-10-2015 06:42 AM
Fast302
06-02-2004 05:31 PM
nhdungeonracer
04-12-2004 06:28 PM
gtbeast87
01-21-2004 06:00 PM
Quick Reply: tach ????????
