Brake light coming on
Old 12-14-2011, 09:45 PM
Project 5.GO!
Project 5.GO!'s Avatar
Default Brake light coming on
For the last month the brake warning light started coming on in the dash when I'm accelerating. When I get up to speed, and lay off the gas, the light goes off after about 5 seconds. If I speed up to pass someone, it goes on again. Short near the ebrake handle maybe?
Project 5.GO! is offline
Old 12-14-2011, 09:47 PM
mattdel
mattdel's Avatar
The light shares a circuit with the brake fluid level sensor, at the master cylinder, and the handle sensor. Check the fluid level first.
mattdel is offline
Old 12-14-2011, 11:02 PM
Project 5.GO!
Good call, the fluid level is low. I bet the intermittent light is the fluid sloshing over the sensor. I better check the bleed valves, because I know there are no leaks at the master cylinder or underhood lines. Any other place the fluid might be going?
Old 12-14-2011, 11:03 PM
Project 5.GO!
Btw, where in the hell did your sig come from?!? How many of us are probably wondering the same thing... lol
Old 12-15-2011, 09:57 AM
mattdel
mattdel's Avatar
My sig is just a random image i picked up.
As far as the leak, anywhere the brake fluid travels is capable of leaking. Master rear seal can leak into the booster, lines can pop anywhere, and the rear wheel cylinders can leak into and out of the rear shoes.
mattdel is offline
Old 12-15-2011, 02:08 PM
Project 5.GO!
You nailed it, I put some fluid in, and no more light. Thanks for the good call!
Old 12-18-2011, 12:25 PM
lxman1
lxman1's Avatar
The fluid drops as the pads and shoes wear. Check them because they may be worn out. Be careful when installing new ones because now that you topped of the M/C, it will overflow when you push the caliper pistons ans wheel cylinder pistons back in.
lxman1 is offline
Old 12-18-2011, 07:06 PM
Project 5.GO!
Good call, I didn't think about that, and I probably would have been on here asking why my reservoir overflowed later. LOL
JonnyBlazeGT
11-03-2015 01:10 AM
bond007
08-26-2015 11:36 PM
kdryan
08-21-2015 04:01 PM
cody.hoeppner
08-12-2015 06:39 AM
cody.hoeppner
08-11-2015 08:08 PM
Quick Reply: Brake light coming on
