91 5.0 cooling problems...
Old 01-05-2012, 12:53 AM
mrnastix
mrnastix's Avatar
Default 91 5.0 cooling problems...
Recently i purchased a new-to-me 91 5.0.. It has an electric fan conversion with a relay from the previous owner, it was working fine up until the fans stopped kicking on and it would overheat. I found something online about grounding out the wire coming off the fan switch, so I grounded it, and the fans came on. First thoughts were I had a bad fan switch so I went ahead and ordered a new fan switch off summit(Vintage Air 11190-VUS electric fan temp switch) that turns the fans on at 192F and a Mishimoto 82C thermostat. I install everything and I am having the same problem, I dig through the net some more and find that some people people have their fan switches installed on the thermostat neck as opposed to the lower intake manifold how mine is. I go ahead and switch the location of the switch and the fan comes on as its supposed to at the correct temperature; except now it won't turn off(and brings the temperature of the motor really low) unless i disconnect the wire going to the switch.
Sorry for the long paragraph but i did my best to try and explain the problem.
Hopefully someone can point me in the right direction for test/solutions to this problem. Thanks in advance!
mrnastix is offline
Old 01-05-2012, 06:54 AM
mattdel
mattdel's Avatar
Seems more of a coincidence than anything else, to me. I'd say you have a sticky relay.
mattdel is offline
Old 01-05-2012, 02:44 PM
mrnastix
mrnastix's Avatar
I don't think the relay is sticking otherwise the fans wouldn't shut off when I disconnect the fan switch wire
mrnastix is offline
Old 01-05-2012, 05:14 PM
Bubba 95SN
Bubba 95SN's Avatar
Why not just test the relay?
Bubba 95SN is offline
Old 01-05-2012, 06:12 PM
mrnastix
mrnastix's Avatar
just went ahead and tested relay and it's fine. i put power to the coil side of it and it clicks on and off fine.
mrnastix is offline
Old 01-05-2012, 07:58 PM
Tony71502
Tony71502's Avatar
Go put a mechanical fan back on. They are cheap if not free... and you won't have to worry about this junk anymore.
E-fan only frees up like 3-5 horsepower of parasitic loss.
Tony71502 is offline
Old 01-05-2012, 10:07 PM
mattdel
mattdel's Avatar
One thing I just thought of: If your temperature sensor is deep enough to touch metal on the inside of it's port, it could ground the sensor out, which could cause the symptoms you have. It's not meant to touch anything but coolant.
mattdel is offline
BOB ROME
07-26-2023 01:54 PM
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
Quick Reply: 91 5.0 cooling problems...
