tail light lens fix question
Old 02-13-2012, 06:40 AM
StalkerGT
StalkerGT's Avatar
Default tail light lens fix question
my tail light lens is seperating from the housing...is there a special adhesive made for them?
StalkerGT is offline
Old 02-13-2012, 05:18 PM
ALMOST STOCK
ALMOST STOCK's Avatar
You can use Silicon if you want to reseal the lens to the housing, the only problem with that is if you ever have to replace the lens.
From the factory they used Butyl Rubber Sealant, which is just about the same as the 3M Windo- Weld.
http://www.tooltopia.com/3m-automoti...ricegrabber_r1
Or you can get a taillight lens repair kit which has the Butyl Rubber Sealant and the clips for the rear taillight lens.
http://www.latemodelrestoration.com/...stallation-Kit
ALMOST STOCK is offline
Old 02-14-2012, 06:34 AM
StalkerGT
StalkerGT's Avatar
Thank you for the info!
Diode Dynamics
28
05-26-2022 12:02 PM
JonnyBlazeGT
11-03-2015 01:10 AM
kdryan
08-21-2015 04:01 PM
chain
08-17-2015 08:52 AM
philster0306
08-10-2015 11:33 AM
Quick Reply: tail light lens fix question
