How much should I pay to have these fixed?
rotors need to be turned or replaced when replacing the pads to remove any warpage or imperfections.
Your shocks/struts can be replaced in an hour by someone who knows what they are doing.
Do NOT purchase the ball joints from summit. Get the Moogs that adder quoted a price on..40-45 each depending on where you look.
As for the struts/shocks it depends on what you do with the car. If it is driven alot on the street just spend what Adder mentioned on Monroe sensatracs.
You could drive the 3 hours to me and I would do it all for well under a shops price.
Sorry im pretty new, does that mean they don't need bled then? (Im being told by my dad he thinks they need bled but being told by guys at work they don't)
Yeah I pushed on the four corners of the car and didn't get anything more then one big bounce and a little squeak, so im thinking the shocks may not be too bad.
the push method really doesn't work too well on mustangs with aftermarket springs....unless you are decently heavy. Driving the car will tell you more.
Bleed them. But if you do make sure you do it right....
bradleyb
11-27-2015 07:50 PM
