Car jerks at cruise
Car jerks at cruise
I have a 94 GT with an automatic. When the engine gets to operating temperature and the engine speed is around 1.5 k, the car will suddenly pull, resume cruise, and pull repeatedly. I have replaced the o2 sensors in response to codes thrown when I first purchased the car March 2011. I have replaced the tps. I have replaced the fuel filter (it needed it badly) I had pulled the egr valve and tried to clean it out with some small improvement. I then replaced the egr valve and checked its' position sensor. I have replaced the distributor due to failed bearings. This problem occurred prior to, and after its' replacement. The only code given in the latest test was the brake sense. I replaced the brake switch and that cleared.I took it out today and coupled a vacuum gauge in the egr vacuum line and then on the intake. There were no vacuum fluctuations that could correspond to the jerking of the car. I have also checked the car with the overdrive on and off. Any Ideas? TIA.
I was expecting some story about some butthead at a get together lol. If you already replaced the fuel filter, have the fuel pressure tested if possible. I not sure on the old 5.0 if you can or not. If the pressure reads normal I would be thinking maybe injectors.
It wouldnt hurt to run a can of Seafoam through it to see if that clears anything up on the fuel side since you said the filter needed it badly
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
