DETONATION 95 5.0 T5 help please!!!
Old 05-21-2012, 10:16 PM
JZTRK
JZTRK's Avatar
Default DETONATION 95 5.0 T5 help please!!!
95 5.0 W/T5 we let the car come up to temp shut it off pulled the spout restarted it and set the timing to 13 degrees shut it down put the spout back in and restarted it and it pings like a s.o.b
so we did the same thing to put back to 10 degres and it dose the same thing any where we set the timing the car has a few mods like msd 6al and msd coil it has a new distributor in it and it runs on 91 octane
JZTRK is offline
Old 05-22-2012, 09:34 PM
mattdel
mattdel's Avatar
Distributor's a tooth off. Or more. Re-stab it.
mattdel is offline
Old 05-23-2012, 02:23 AM
Samsbolt390
Samsbolt390's Avatar
Default Detonation under load with spout in...
The SN95 in question is mine, after replacing a bad msd coil it was cheap insurance to install a new Dist (the old one had corrosion). It was installed exactly like it came out and the timing was reset with the spout out, I decided that since it passed emissions that I could bump it to 12 degrees, we locked it down at 12.5 and it ran solid so I figured done deal and installed the spout. The minute I pulled away it began to knock and back fire under load and also backfired through the exhaust while slowly accelerating. I pulled the spout again and it ran fine. My mileage went away so back in with the spout after setting it to 10degrees. Felt great around the block but after a restart it was missing and knocking under load. I can see where if the dist is a tooth off with the spout in it maybe to far advanced by the computer. If this sounds logical than it maybe the next step but I'd like some more feed back If you all don't mind. Thanks Sam.
Samsbolt390 is offline
Old 05-23-2012, 10:25 AM
mattdel
mattdel's Avatar
Backfire + recent distributor install = distributor isn't in correctly.
mattdel is offline
jwog666
12-27-2021 08:09 PM
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
Quick Reply: DETONATION 95 5.0 T5 help please!!!
