No start
Old 06-11-2012, 08:44 PM
30coupe1
30coupe1's Avatar
Default No start
I have a 89 5.0 with a vortech s trim. The car ran and then i started to have problems with idle and it starting. Now the car will not start. I have spark at the plugs. I tested fuel pressure and the first cycle of the key i only had 11psi, each cycle of the key it build more until it stopped at about 42psi. But the pressure bleeds off. Isnt it supposed to hold constant? The car has a t rex helper pump with the vortech kit. What could cause a no start like this? Please share your imput.
30coupe1 is offline
Old 06-12-2012, 06:14 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
it will hold a little while usually but, it will bleed off. How quickly does it bleed off?
Have you tried spraying a little brake cleaner or something to start it?
TrimDrip is offline
Old 06-12-2012, 06:52 PM
mattdel
mattdel's Avatar
scrap the helper pump and put a 255 walbro in the tank
mattdel is offline
Old 06-21-2012, 10:22 PM
30coupe1
30coupe1's Avatar
I got a walbro 255 pump now and still now luck. Anyone got any ideas? Computer?
30coupe1 is offline
Old 06-21-2012, 10:29 PM
mattdel
mattdel's Avatar
Pressure situation resolved?
mattdel is offline
Old 06-22-2012, 03:49 PM
30coupe1
30coupe1's Avatar
Im really not sure because i rented the gauge the first time.
30coupe1 is offline
Old 06-22-2012, 04:40 PM
mattdel
mattdel's Avatar
Well you need to rent it again then. Should have held on to it, Autozone's policy on rental tools is basically this: once you rent it, its yours till you return it. The rental price is exactly the same as the cost of the item. Anyway, its always a good idea to recheck your results.
mattdel is offline
Old 06-25-2012, 08:09 PM
30coupe1
30coupe1's Avatar
I did rent the gauge again and now my pressure is 40 and holds but still no start.
30coupe1 is offline
Old 06-25-2012, 10:08 PM
mattdel
mattdel's Avatar
rent a noid light set and check injector pulse
mattdel is offline
Old 07-04-2012, 01:34 PM
30coupe1
30coupe1's Avatar
I used a test light and pulled one of the plugs going to the injector. It flashed when the motor was turned over.
30coupe1 is offline
Quick Reply: No start
