Full timing for pump gas 331 stroker engine?
Hi fellas. I have a pump gas(10:6 compression) 331 stroker motor. Was jus wondering what full timing is. Ive heard 33,34,35,36. Im going to spray a 150 shot of nitrous to it and i wanna kno where to take my 2 degrees out from and b safe.
Thanks
Thanks
You take two motors built exactly alike, there is a good chance they will run better on different timing settings.
No one can accuratly tell you what timing you need. You need to take the car to the track. Start low and raise the timing until it slows down....or pings.
probably the difference between a wet & dry system, or he's just leaning on the side of caution, which I don't particularly advocate against when using n2o.
