Engine cutting out while driving?
Old 06-15-2012, 08:29 PM
Topher306
Topher306's Avatar
Default Engine cutting out while driving?
Just installed our 306 crate motor last weekend. It idles pretty well around 700-1000 rpm. But when I take it out, most times when I let off the accelerator, weather it's to slow to a stop or even cruising at speed, the car just shuts off. The red battery amp light will come on, and I'll have to restart the car. Usually it just starts right back up, but it does it repeatedly. Any ideas on causes?
Topher306 is offline
Old 06-15-2012, 10:04 PM
craig71springsport
craig71springsport's Avatar
Sounds like you have a loose wire possibly. Make sure it's all tightened up. Either that or it's dying for fuel or air. Does it just quick cut out or sputter to a stop?
craig71springsport is offline
Old 06-16-2012, 04:52 AM
Topher306
Topher306's Avatar
Just a quick cut, usually I don't even know it's dead until I try to turn the wheel and the power steering is gone.
Old 06-16-2012, 10:17 AM
mattdel
mattdel's Avatar
Releasing the throttle will cause the FPR to regain vacuum and lower the fuel pressure, if this wasn't happening the vehicle would stall from having increased pressure @ idle.
But, like already said, usually things of this nature tend to be electronic in nature.
mattdel is offline
Old 06-16-2012, 02:38 PM
Topher306
Topher306's Avatar
I had kind of been thinking electrical, but wasn't sure where to start with it. With what you were saying about the pressure at idle from the FPR, would that be suggesting the FPR possibly not working?
Old 06-16-2012, 03:50 PM
mattdel
mattdel's Avatar
Right. Just a theory, but plausible. Not too many things can cause the engine to die completely from just releasing the throttle. Obviously spark or fuel related.
mattdel is offline
Old 06-16-2012, 04:37 PM
Topher306
Topher306's Avatar
What would be the easiest way to test that theory?
Old 06-16-2012, 05:04 PM
mattdel
mattdel's Avatar
Rent a pressure tester from autozone and hook it up.
mattdel is offline
Old 06-19-2012, 10:27 PM
Topher306
Topher306's Avatar
In the interest of time we had it checked out, turns out there was a bad hose on the intake manifold causing a vacuum leak. Got it replaced as well as fiddling with the timing and TPS and now it runs great
djbigskrilla
09-20-2022 01:04 AM
drfister
05-03-2018 10:38 PM
Gary Ugarek
63
12-11-2015 02:01 PM
Tyoung68
08-25-2015 04:31 AM
HIS S-197
08-10-2015 05:47 PM
Quick Reply: Engine cutting out while driving?
