Low voltage at IDLE.. Anyone???
Old 07-22-2012, 05:48 PM
BeerThurdy
BeerThurdy's Avatar
Question Low voltage at IDLE.. Anyone???
So I've got an 89 5.0, MSD 6AL box, OE Alternator, MSD Cap and Rotor, and a blaster coil that replaced the OE Ford coil.
When I'm at Idle, the voltage meter in the dash reads around 4 or 5, as soon as I accelerate, it goes up to the normal 13-14 range. The only thing this affects - that i have noticed - is the turn signals; they blink VERY slow when im sitting at idle and speed up when i accelerate...
So tired of chasing wires, anyone else have this problem and has solved it???
-Jonny
BeerThurdy is offline
Old 07-22-2012, 05:57 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
The computer would should down the car before it got that low. The gauge is wrong.
TrimDrip is offline
Old 07-22-2012, 07:39 PM
thegstring
thegstring's Avatar
I agree and dont agree with TrinDip, i have the same issue with my turn signals, but 5 volts and the car would shut down. Mine dips under 12 with lights and stereo on and my turn signals WON'T flash at all. Try replacing the turn signal flasher relay (if you can find it, mine is still MIA) with an electronic one instead of the bimetal, and bite the bullet and replace the alternator with a 3g one. Should give you no more issues.
thegstring is offline
Old 07-22-2012, 08:45 PM
enfausn
enfausn's Avatar
You need a bigger alternator. Bite the bullet and upgrade, you'll be glad you did. The turn signals blink slow because you don't have enough power.
enfausn is offline
Old 07-22-2012, 08:52 PM
00blackstang
00blackstang's Avatar
Put smaller pulley on the alternator. Problem solved
00blackstang is offline
Old 07-23-2012, 10:17 AM
ttocs
ttocs's Avatar
your not using underdrive pullies are ya?
ttocs is offline
Old 07-23-2012, 01:02 PM
BeerThurdy
BeerThurdy's Avatar
Ive been playing with the idea of the alternator. Its pretty new - or looks newish - but there is no indication of model, year, amps, nothin like that so maybe ill try and replace it. thanks guys.
Old 07-24-2012, 06:39 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
If the battery is good, it shouldn't that low even if the car doesn't have an alternator on it. I bet if you put a battery tester on it, it would read over twice what the gauge is showing.
TrimDrip is offline
Old 07-24-2012, 08:51 PM
mattdel
mattdel's Avatar
Your description of the problem is the signs of a low amperage alternator combined with not-perfect wiring. The gauge is fine, it specifically shows alternator voltage when the engine is on. Look into a 3G conversion
Stock foxbody alternators are 65 amps, and so are the part store replacements. Combine that with wiring that has a bit more resistance in it due to age, and you get a dimming headlight, slow blinker, dipping gauge. 3G alternators are stock in 94-98 Mustangs and some earlier T-birds as well. They come in 110 and 130 amp.
MJR if you happen to see this, can you look into getting the pictures in that link I supplied working again?
mattdel is offline
jwog666
12-27-2021 08:09 PM
CS2007
06-25-2019 09:45 PM
TCStangerv6
10-11-2015 05:57 PM
TfcCDR
09-14-2015 12:08 PM
cbird1177711
09-03-2015 08:43 PM
Quick Reply: Low voltage at IDLE.. Anyone???
