o/r h-pipe o2 extension?
Old 08-09-2012, 10:25 PM
hashpipe956
hashpipe956's Avatar
Question o/r h-pipe o2 extension?
do i need to install o2 extension harness with the new bbk o/r h-pipe , still have smog pump need to know want to install in next couple of days
hashpipe956 is offline
Old 08-10-2012, 01:01 AM
mattdel
mattdel's Avatar
Nope.
mattdel is offline
Old 08-10-2012, 07:38 AM
Tony71502
Tony71502's Avatar
Only need extensions with long tubes. Check for exhaust leaks with a bottle of soapy water after you install the h-pipe. BBK did a sucky job on my X-pipe and there were pin holes(pores) in their welds. I had to fix them.
Tony71502 is offline
Old 08-10-2012, 02:33 PM
Boss_Hotrod
Boss_Hotrod's Avatar
I noticed when I switched my wiring around and had a tube k-member installed that replacement Bosch o2s had long enough wires to reach without the extenders. Might be something too look into if you have old o2s. Dont know if the k-member is needed or just rerouting the wiring.
Boss_Hotrod is offline
Old 08-11-2012, 12:03 AM
Tony71502
Tony71502's Avatar
Extensions are only needed with long tube headers.
Old 08-12-2012, 02:41 PM
lxman1
lxman1's Avatar
^^^ What they said. The O/R pipe has the sensors in the stock position. My cheap Summit brand 2.5" O/R H-pipe fits great and has never leaked.
lxman1 is offline
Old 08-12-2012, 06:48 PM
Boss_Hotrod
Im running BBK longtubes. I had the extenders installed with the stock k-member but when I switched it to a tube and changed the wire routing I was able to do away with the extenders.
KLO
02-23-2010 10:31 PM
rygi23
Mach 1 Section
59
03-27-2008 05:30 PM
04CrimsonGT
06-13-2006 02:14 PM
RiCe_KiLlEr
12
06-01-2006 01:40 PM
50mustanggod
04-01-2006 04:41 AM
Quick Reply: o/r h-pipe o2 extension?
