canister purge hoses?
Old 10-25-2012, 12:10 AM
MY5TANG94
MY5TANG94's Avatar
Default canister purge hoses?
Does anyone know where i can get the hoses for the canister purge solenoid? Are they a certain type of hose? This might be a dumb question but i just want to make sure i get the right stuff. And also do you just have to take off the fender to get at all of the hose?
MY5TANG94 is offline
Old 10-25-2012, 09:30 PM
mattdel
mattdel's Avatar
If memory serves me, and it usually doesn't, but I'm pretty sure its just regular 'ol fuel hose. IDK about the fender tho, never had an SN of my own
mattdel is offline
Old 10-26-2012, 09:35 AM
MY5TANG94
MY5TANG94's Avatar
ok thanks for the response and don't worry if i ever get pissed off enough i might sell you mine lol
Old 10-26-2012, 02:49 PM
dawson1112
dawson1112's Avatar
I never took the fendere off mine I just removed the wheel and the inside plastic cover just to replace the lines. It probly would have been easier to see with the fender removed. And the lines that go to the purge solenoid are the small hard plastic or nylon vacuum lines. I went to a junk yard down the road from me and they just let me go out and get what I needed. And under the fender are also the egr solenoid lines all these lines are kind of tied together with rubber ends and plastic splitters that split the vacuum signal between the purg solenoid , egr solenoid , the air diverter solenoid , and then return to the egr and diverter valve . You are better off to go to a junk yard and get the entire set up of vacuum lines as they are all different colors and leangths with the rubber boots on the end of em to go to the specific items.
dawson1112 is offline
Old 10-26-2012, 10:23 PM
MY5TANG94
MY5TANG94's Avatar
thanks dawson, the only thing im concerned about is my lines are not plastic they are some sort of rubber line. not sure if the guy before me replaced them or not but thats what they are now. i think i know what lines you're talking about tho. Ill post a picture soon, maybe that'll help.
mrtrodonet
09-19-2020 03:12 PM
lmurf60
09-24-2015 10:07 PM
Demodulates
09-18-2015 11:14 AM
TfcCDR
09-14-2015 12:08 PM
MusicCity615
09-12-2015 07:05 AM
Quick Reply: canister purge hoses?
