Replaced Rack n pinnion now when turning rims grind on control arm needhelp
Old 11-18-2012, 07:58 PM
Leeh1979
Leeh1979's Avatar
Default Replaced Rack n pinnion now when turning rims grind on control arm needhelp
I have a 1994 mustang. Rack and pinnion was leaking so I went to advance auto parts and bought a fenco rack and pinnion. I installed it on the car. And now when I turn the steering wheel all the way to the right. The right wheel is scrapping on the lower control arm shaving metal off of the edge of the rim. And on the other side. The tire is rubbing on the stabilizer. And if I turn the wheel to the left it is basicly visverssa. My problem is that when I turn the wheels the rack in pinion is turning way to far. And not stopping at its certain point. And after I put it in I had it aligned. I checked to see if I missed something. Or to see if the rack and pinnion was not tight enuff. Eveything looks good. There is nothing loose. I talked to a friend and he says he doesn't thing it is the rack and pinnion. But that is the only thing I replaced on the car. I never had a problem with the old rack and pinnion turning to far. I don't know what to do. If anyone knows anything please let me know! Thank you!
Last edited by Leeh1979; 11-18-2012 at 08:14 PM. Reason: Forgot to put year of my mustang
Leeh1979 is offline
Old 11-18-2012, 09:07 PM
mattdel
mattdel's Avatar
Know the part # of the rack you installed?
mattdel is offline
Old 11-18-2012, 09:09 PM
Boss_Hotrod
Boss_Hotrod's Avatar
You can get a set of rack limiters to keep the wheels from turning too sharp. You may have gotten a different ratio rack. I think they make a 15:1 and a 16:1. Should notice any difference though. Check some Mustang sites for the limiters.
Boss_Hotrod is offline
Old 11-18-2012, 10:56 PM
Leeh1979
Leeh1979's Avatar
Default Part number
This is the part number from the website. I did not get the part number off of the box the rack and pinion came in. Advance auto parts is where I got it. Fenco Part No. RP8704
Leeh1979 is offline
Old 11-19-2012, 12:38 AM
mattdel
mattdel's Avatar
SN's had no variation in ratio, so if this problem did not exist before, then something is wrong with the install or you got a fox rack.
mattdel is offline
JonnyBlazeGT
11-03-2015 01:10 AM
GimpyHSHS
08-29-2015 06:30 PM
cedarmn
08-28-2015 09:51 PM
Mobiusone stang
08-24-2015 04:08 PM
inyadreems
08-21-2015 09:10 AM
Quick Reply: Replaced Rack n pinnion now when turning rims grind on control arm needhelp
