dipstick help
Old 12-14-2012, 03:48 AM
Ecstasy
Ecstasy's Avatar
I wouldn't say it's already broken because my car had this same issue, I could get the tube and pull it out push it in pull it out. The vibration caused it to come loose, even when pushed in all the way, because once you put headers on it you can't use the bolt to hold it on, though I'm sure you can bend the tube, I just put a new dipstick on it.
If you want a new dipstick, yes they have $60 & 80 one, depending if you want locking or not, which I did because I just wanted it. Summit sells a Lokar dipstick(get the block entry one) which has a hose and it's braided so it's flexible, really easy to install and you can route it to mount to your headers via one of the bolts.
Ecstasy is offline
Old 12-14-2012, 07:29 AM
majohns
majohns's Avatar
Ok thanks i will look it up!
majohns is offline
Old 12-14-2012, 07:40 AM
Ecstasy
Ecstasy's Avatar
It's the best way to go, and it looks nice and has orings on it as well, two to be exact. I'd spend the money and get the locking one because if you ever decide to build up your motor higher compression motors have a problem sometimes with blowing the dipstick out and the locking one prevents that.
Ecstasy is offline
Old 12-15-2012, 05:37 AM
majohns
majohns's Avatar
Do you by chance have any part numbers?
majohns is offline
Pyrate Dave
09-10-2015 07:30 PM
KEM Motorworks
08-14-2015 10:13 PM
86gt5.0HO
06-24-2005 02:50 PM
cobra1995
03-01-2005 04:48 PM
Quick Reply: dipstick help
