stupid/basic questions i need help please 95 5.0
Ive got a 1995 5.0 mustang and just have some stupid questions. Im trying to post pictures for more info and clarity. but basically i believe i have non egr, and you should be able to tell by the picture.Also, i have a pressure gauge on my fuel rail, and it normally reads about 22 or so psi, would that be what my injectors are? I know the inectors are aftermarket, i just dont know what exaclty. I also have to random cords not connected to anything and would love any input.
http://imgur.com/a/rLXvt
Sorry, couldnt get the pics uploaded, so here is the whole album i rally really appreciate any input!
Thanks for the help!
Is that engine even running? If so Id say that gauge that's connected to the fuel rail is shot. Min fuel pressure is 35 psi . Those 2 random plugs , the one with 4 pins used to plug into the egr position sensor and the other one with 2 pins hooked up to your fuel vapor purge valve. So you are correct the egr is gone , Also I can just barely make out a fuel injector under the intake and it looks to be the stock 19# yellow top injector.
Yea they are yellow, and i have a blown head gasket that im replacing in a month or so, what is the fuel vapor purge valve? And i figured my egr wasd gone, just needed some conformation. Yall helped alot, i was worried bout those random wires and everything.
