Efi 4cyl swap help ASAP
Hello I have a 92 4cyl that I did a v8 swap on n I'm going to get a computer and a harness today and the guy said a 93 computer and harness will hook right up to where the old 4 cyl computer was and he said he's going to give me all the sensors for on the motor to and the intake and I was wondering if there was anymore I needed n if this sounded right with the wiring
The computers are located in the same place, and the harness goes through the same hole in the firewall. There are 3 separate under hood harnesses for the V8, and you need all three: 1 from the computer to the sensors, one from the coil area to around the radiator to thee alternator, and the engine harness. You'll also need the barometric sensor that mounts on the firewall.
Matt's 95 Stang
10-05-2015 07:16 AM
