valvetrain noise? rockers tight
Old 02-17-2013, 09:43 AM
9165pt0
9165pt0's Avatar
Default valvetrain noise? rockers tight
been hearing a ticking noise, sounds like coming from rear of driver side valve cover/intake area. you can hear it at idle, and it gets louder under throttle. low pressure seems low at times as well. someone said it sounds like a loose rocker arm. i pulled the valve covers, and none of the rockers are loose. however some of them are sitting higher than others, id think due to valve position. is this normal, or should they all be even? ive had 2 exhaust shops count out and exhaust/header leaks, running out of ideas
9165pt0 is offline
Old 02-17-2013, 11:39 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
lifter may not be pumping up due to dirt or something of the sort
mjr46 is offline
Old 02-17-2013, 09:16 PM
9165pt0
9165pt0's Avatar
is there a way to verify a bad lifter without pulling the intake?
9165pt0 is offline
Old 02-17-2013, 11:06 PM
mattdel
mattdel's Avatar
Yeah. A proper check of rocker tightness would verify. Rotate the engine until the valves you wish to check are seated(up) and check them then. A collapsed lifter would be loose enough to make the pushrod almost fall out.
mattdel is offline
Old 02-19-2013, 03:41 AM
petrock
petrock's Avatar
One thing to note is that hydraulic lifters will bleed down over time. I'm not sure how long though, but it is normal. So you want to check them within a few hours of the last time the car was running.
Its also common to mistake an exhaust leak for a lifter tick. Take a squirt bottle and fill it with water and a little bit of dish soap (enough to make it a little bit sudsy). Then, with the car running, squirt the water/soap mix all over the exhaust manifold. Then wait for bubbles to appear. Any place you find bubbles is an exhaust leak. It could be a bad gasket, cracked exhaust manifold or loose exhaust flange bolts. Good luck...
petrock is offline
Old 02-19-2013, 09:17 AM
eb2gt
eb2gt's Avatar
if none of the above is the problem look for a bent or broken push rod.
We had the end of push rod break off and had a tick like sound.
eb2gt is offline
mrtrodonet
09-19-2020 03:12 PM
Sixer4Life
10-12-2015 04:26 AM
KingRando
10-02-2015 08:06 AM
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
Sixer4Life
09-28-2015 07:05 AM
Quick Reply: valvetrain noise? rockers tight
