camshaft replacement help,Rocker arms help
Old 02-20-2013, 12:38 AM
americanfisher93
americanfisher93's Avatar
Default camshaft replacement help,Rocker arms help
I am going to replace a cam soon, I just need a little help, i know its recomended to replace the bearings, but is it tough as far as replacing them? I mean I know that supports the cam if i am not mistakin, my question is how they actually go on there, pressed on, bolted, screwed etc.
I have stud mount rockers and i know for pedistal mount they justsit on the ped. For stud i understand its the pushrod and spring that pushes holds them if im correct. My question is how do I correctly align them?
americanfisher93 is offline
Old 02-20-2013, 12:40 AM
americanfisher93
And any help is greatly appreciated btw
Old 02-20-2013, 01:17 AM
tinman
tinman's Avatar
I'll take the part about the cam.
I really doubt if you need to replace the bearings at all unless they have been removed.
As a fact they are technically not bearings but rather they are bushings anyway.
tinman is offline
Old 02-20-2013, 06:48 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
to center the roller tip on the valvestem so one side is not hanging off to the left or right more, about all you can do is move the guide plate side to side if you have such, after that if one stays centered while another hangs off to the side, at that point it's time for adjustable guide plates. I've had to use such many times.
mjr46 is offline
Old 02-20-2013, 08:47 PM
americanfisher93
Thanks for all the info! also,Im looking for a cam, found one on corral for under 200 its a comp cam 282, I didnt know if the came is to big for the engine 302. I have ported gt40ys cobra intake, I know a lot of restriction, its just for the time being, 1.6 rr, and exhaust to support it. Let me know, thanks again!
Old 02-21-2013, 06:50 AM
mjr46
mjr46's Avatar
you'd better have a health top end for the xe282 cam as well as the proper valvetrain components, that cam needs some stout springs or prepare for valve float/rpm issues, I ran that cam in a high compression 302 as well as my 347 for a while
mjr46 is offline
Old 02-21-2013, 09:22 AM
americanfisher93
Well i have ported gt40ys, behive springs up to .575, hardened puchrods, 1.6 rr, as fo intake I have cobra intake and thats about it. Would you consider that enough, let it be know my compression is still probably the 9:1 stock.
Old 02-21-2013, 11:58 AM
mjr46
mjr46's Avatar
nope, doubt those springs will handle that cam, www.flowtechinduction.com/ email ED and he can set you up with what you need. The issue you'll run into finding a stout spring for that cam and using those stock style heads are most will require you to machine the spring pockets, however ED can most liklely set you up with a lsx style spring that may not require such, he is a better authority on that
mjr46 is offline
Old 02-22-2013, 12:30 AM
tinman
tinman's Avatar
I really think the cam was designed for more than 9:1 compression, maybe 10:1 would be okay.
The cam will 'work' at 9:1 compression but you won't get quite all the benefits from it as cylinder pressue won't be high enough........
tinman is offline
5.0muscle
01-11-2016 01:17 PM
poke68
12-15-2015 06:25 PM
copestang
10-11-2015 07:17 AM
GimpyHSHS
09-18-2015 12:27 PM
Dragonus18
09-09-2015 01:21 AM
Quick Reply: camshaft replacement help,Rocker arms help
