Fuel mileage
Old 04-11-2013, 12:01 AM
a6falcon5
a6falcon5's Avatar
Question Fuel mileage
I have a 1988 LX NB and I'm getting about 12 MPH. Its stock with a 5 speed, the temp gauge moves a 1/4 of the way up at operating temp. I runs great but after driving a while and it's turned off and restarted it won't idle for a few minutes maybe 2-3 then it comes back and runs fine again. I just noticed it idling at about 1200 rpms and fluctuates down to 1000 and back up. Any suggestions would be greatly appreciated.
a6falcon5 is offline
Old 04-11-2013, 06:58 AM
BabyGT
BabyGT's Avatar
Vac lines, fuel pump, fuel filter, aic, bad gas, cats clogging up, could be a lot of things. I'd start with vac lines, fuel filter myself though.
BabyGT is offline
Old 04-11-2013, 08:29 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
somethings wrong...i used to get 30mph with my 91 GT vert...
rmodel65 is offline
Old 04-11-2013, 10:53 AM
88 orangepeel notch
88 orangepeel notch's Avatar
Yeah, you should be getting mid 20's easily without gramma driving. Sounds like your temp gauge is working but don't trust its accuracy. As for the stumbling/no idle on restart, sounds like your getting raw fuel dumped in when you turn the car off (injector stuck open). Watch behind the car on restart, does it push alot of black smoke?
88 orangepeel notch is offline
Old 04-11-2013, 11:20 AM
BabyGT
BabyGT's Avatar
Say what??
BabyGT is offline
Old 04-11-2013, 01:17 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
easily...got that with the 3.55s my freeway mpg dropped to about 26mpg. if you get some new O2's from Bosch(iirc thats fords OE maker) bump the timing up and all the wires,plus etc are in good shape its easy
rmodel65 is offline
Old 04-12-2013, 09:22 PM
nitrous_bob
nitrous_bob's Avatar
my '93 with 4.10's gets 21 MPG so long as i stay under 3000, and thats with AC on
do you drive like you stole it ??? cuz at the track i gat about 10 1/4 mile passes on a 1/2 tank
thats not a good indicator
nitrous_bob is offline
Old 04-13-2013, 02:26 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
May not be the problem but, the temp gauge should be around halfway. Your car is not fully warm until it gets above 180 degrees....At least I believe it is the same as the mass-air cars...
TrimDrip is offline
GimpyHSHS
19
12-19-2023 01:12 PM
4cylinderplus2
10-09-2020 07:45 PM
Sixx
10-05-2015 07:36 PM
svfetter
10-05-2015 11:39 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: Fuel mileage
