I need all the help i can get from the fuel injection pros
alright I just got off the phone with bbk and he said the maf is calibrated for 19# so I just need somebody to confirm that I have 30# injectors and that this setup would realy make me run this rich
Those injectors look like 19 to me, and if the MAF is 19, then you're good on that regard.
On the other hand, a cobra computer is expecting 24#, and I'm not too sure it would play nice with 19's, calib'd MAF or not.
Maybe. If the pressure is good I'd look into finding a normal computer. I honestly think there's a conflict there. Cobra computers are calibrated for 24 right out of the box and it's not a normal thing to go backwards in regards to such.
I checked my fuel pressure with the FPR with vac unhooked, I have a constant 40lbs no matter what the rpms are. with the vac plugged in I have 38lbs at idle and it drops when I hit the gas down to about 26-28lbs at wot.
im going nuts I just changed the fpr and the comp and nothing still rich....crazy rich... I now have 38 lbs of fuel pressure at idle and 40lbs when reved.. when I took the upper intake off I noticed fuel on the gasket in between the rear 4 intake ports (GT40 intake with a 1 inch spacer) so I got 2 new gaskets. also noticed a little bit of carbon in those same ports. when i drove the car the other day it would pop (through the intake?) when shifting after gettin into it...im starting to think theres a bad vacuum leak somewhere i haven't seen or cant get to...i sprayed the spacer and gaskets with break clean when it was running so its not leaking externally maybe a cracked intake, head or leaking lower gasket into the lifter valley? idk where to go from here or how to diagnose internal lower intake leaks?
jwog666
12-27-2021 08:09 PM
mrappe
09-26-2015 10:16 AM
