cobra intake throttle body size / intake gasket questions
Old 09-09-2013, 05:41 PM
mebirkle
mebirkle's Avatar
Default cobra intake throttle body size / intake gasket questions
Hello,
I have a cobra intake that I'm reusing the throttle body on a user trick flow street burner intake.
Can someone point me to the stock opening size of the cobra intake so I can get the right throttle body gasket? I see both 70mm and 75mm options.
Bonus question:
Would you happen to know which lower intake gaskets I should go with as I have edelbrock heads and am putting on a trick flow intake. Stock, Edelbrock, or trick flow??
So confusing...
Thanks!!!
mebirkle is offline
Old 09-09-2013, 09:33 PM
Duncan_GT
Duncan_GT's Avatar
Measure your intake ports on the heads, and find the equivalent felpro set. If they do not match the intake runner ports, then you gasket match.
The opening to the stock cobra upper is 70mm
Duncan_GT is offline
Old 09-10-2013, 03:00 PM
mebirkle
mebirkle's Avatar
Thanks Dunca... I have been told to get the Felpro one for the edlebrock.
mebirkle is offline
Old 09-10-2013, 09:01 PM
Duncan_GT
Duncan_GT's Avatar
I use felpro for everything
djbigskrilla
09-20-2022 01:04 AM
mirandaandjimmy
11-16-2015 08:51 AM
my96mustang
08-24-2015 06:12 AM
Figure8allday
08-22-2015 11:11 AM
stanngg
08-12-2015 03:43 PM
Quick Reply: cobra intake throttle body size / intake gasket questions
