bad torque converter??????
Old 09-22-2013, 04:59 AM
95greengt
95greengt's Avatar
Default bad torque converter??????
ok so i am trying to figure out what is wrong with my car and i am leaning towards a bad torque converter. My car is an automatic 95 gt. when it shifts at low RPM it feels like when you would shift a manual car into to high of a gear? But for the most part it does not do it if i am driving the car hard.
Any help would be greatly appreciated!!!
95greengt is offline
Old 09-22-2013, 08:16 AM
uedlose
uedlose's Avatar
Do you mean it shutters? If yes they make a valve to put in the valve body to fix that and a fluid change would also help.
uedlose is offline
Old 09-22-2013, 06:14 PM
95greengt
95greengt's Avatar
where would I find info on where to get this valve? I am starting to get irritated with this.
Old 09-23-2013, 05:47 AM
petrock
petrock's Avatar
Its been my understanding that the torque converter does not have anything to do with your shift points. Its all about fluid pressure in the valve body. I could be wrong on that though…
btw, an automatic will never have the same shift points as a manual. Just sayin’...
petrock is offline
Old 09-23-2013, 09:00 AM
uedlose
uedlose's Avatar
Transgo sells the kit but if the converter is damaged to much it may not fix it.
uedlose is offline
Old 09-26-2013, 12:15 PM
msd143
msd143's Avatar
Mine is doing the same thing. What it sounds like is when your doing a pull on an engine dino, you can hear the engine bog and then will slowly come back to normal.
I dont seem to loose any power, you just can really tell that right after the shift, you can hear and feel the engine bog down and come back to normal and then shift to next gear.
msd143 is offline
mtgldr
02-03-2024 09:00 PM
poke68
12-15-2015 06:25 PM
spamedic
09-09-2015 12:15 AM
Quick Reply: bad torque converter??????
