Distributor Help.
Old 09-28-2013, 03:23 PM
BIGTY2009
BIGTY2009's Avatar
Default Distributor Help.
Hey all,
Im not experienced with distributors. I pulled mine when I took the intake mani and valve covers off. I put a line on the cap and on the block.
I finally have everything put back together but it wont turn over. I am thinking somehow or somewhere I got the dist out of whack. There is a #1 on the dist cap which I have going to the front left cylinder. Im assuming that is my #1 on the firing order.
How do I check which cylinder is my #1? Also, I followed the the proper firing order from #1 counter clockwise. It tries, but wont turn over.
Any ideas? Thanks.
Tyler
BIGTY2009 is offline
Old 09-28-2013, 03:48 PM
dawson1112
dawson1112's Avatar
Remove cylinder 1 plug front of engine passenger side. Rotate engine by hand using a socket and breaker bar on the crank / balancer bolt. Bring the #1 up to tdc on the compression stroke you can use verify this by having some one turn the engine over slowly while you hold your finger over the plug hole till you feel pressure build under your finger. Use a wood dowl or similar and insert into plug hole you will feel the piston in there and when you start slowly turning the crank the dowel rod will move up or down If it start to move down you have gone to far. If it moves up continue cranking till it stops going up and just barely starts to drop again . This is TDC , the mark on the 0 degree mark on the balancer should line up with the timing pointer.
Once you are certain you are on tdc compression check the dizzy , the rotor should be pointing at the #1 spot on the cap... If its not your dizzy is off .. You need to restab it. There is a line on the base of the distributor that should line up with a mark on the block also ,, Look in this first picture to show where the line should be on the dizzy base ,, the 0 is where there is a notch in the block
You dizzy should look similar to the picture where the #1 is located and the clips are.
dawson1112 is offline
Old 09-28-2013, 10:26 PM
BIGTY2009
BIGTY2009's Avatar
Wow, lots of great information. Ill review this and try again.
Thank you very much
Tyler
Old 10-11-2013, 11:16 PM
Chris_vazz
Chris_vazz's Avatar
My mustang won't turn on, the key turns but it just won't turn completely on, at first it was the distributor rotor and I replaced but it broke again, so I bought me a whole new distributor, but it won't turn on, when I turn the key it sounds like it does not have gas, but it has a quarter of a tank, could it be that I didn't plug in the right wires into the cap..
Chris_vazz is offline
Old 10-12-2013, 07:29 AM
Duncan_GT
Duncan_GT's Avatar
Is it turning over at all (do you have power to the starter)? Have you checked your fuel pressure? Whats your timing set at? Dizzy stabbed correctly? Firing order?
We need a little more input than "my mustang won't start".
Duncan_GT is offline
Old 10-12-2013, 07:32 AM
dawson1112
dawson1112's Avatar
lol is it plugged in??
bradleyb
11-27-2015 07:50 PM
Thunderball
15
11-22-2015 11:49 PM
Dathan
10-05-2015 05:52 AM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
mustangheaven
09-29-2015 11:00 AM
Quick Reply: Distributor Help.
