explorer gt40 heads with HO cam?
Old 01-30-2014, 10:22 PM
9165pt0
9165pt0's Avatar
Default explorer gt40 heads with HO cam?
I have read that the explorer gt40/gt40p heads had weak valvesprings. Some say they are the same at e7 valvesprings. Im not sure which is correct. Im sticking with the stock ho cam, wondering if the gt40 explorer valvesprings will hold up to 5200rpm?
Any experiences with ppl who have used the explorer valvetrain and ho cam is appreciated. Thanks
9165pt0 is offline
Old 01-30-2014, 11:29 PM
bluebeastsrt
bluebeastsrt's Avatar
Those parts will work fine together. no worries.
bluebeastsrt is offline
Old 01-31-2014, 09:59 AM
9165pt0
9165pt0's Avatar
ok thanks. any idea of how much spring pressure is needed? Im having a machine shop check out the springs for me.
9165pt0 is offline
Old 01-31-2014, 02:09 PM
bluebeastsrt
closed 75. Open 215.
Old 01-31-2014, 03:15 PM
9165pt0
9165pt0's Avatar
ok sounds good. my buddy thought 90lbs and 260lbs for 5000rpm. idk where he got those specs. but ill be sure to check the specs of these to what you stated. thanks again
9165pt0 is offline
Old 01-31-2014, 04:55 PM
dawson1112
dawson1112's Avatar
IIRC the gt40P heads have a higher spec spring on them than the gt40 heads.
dawson1112 is offline
Old 02-03-2014, 10:30 PM
9165pt0
9165pt0's Avatar
the machine shop told me my seat pressure was 80lbs. is this enough for the stock ho cam?
9165pt0 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
kevsgt
10-09-2015 10:12 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
Drastang
09-30-2015 03:48 AM
Quick Reply: explorer gt40 heads with HO cam?
