Ford 7.5 > 8.8 swap
Old 02-24-2014, 09:12 PM
Krochus
Krochus's Avatar
Default Ford 7.5 > 8.8 swap
I'm in the process of prepping a 87gt's 8.8 rear axle to go into my LS swapped 4cyl 92 notch.
I have one bad axle shaft that needs replacing in the 8.8, I'm under the impression that the axle shafts for both rear ends are the same. Can anyone confirm this?
Also are the drum brake assemblies the same? It'd save some work to be able to carry these over from my 7.5
Krochus is offline
Old 02-25-2014, 09:27 PM
reldla1996
reldla1996's Avatar
The rear brakes are the same on the 7.5 as the 8.8, or at least they were on 89's. Can't confirm on the axles.
reldla1996 is offline
Old 02-26-2014, 02:08 AM
tinman
tinman's Avatar
I think the axles are the same.
Never have done a swap like this but I don't know why they wouldn't be......
tinman is offline
Old 02-26-2014, 07:54 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
axles and brakes are the same, I've done the swap more than once
mjr46 is offline
Old 02-27-2014, 08:28 AM
uedlose
uedlose's Avatar
Axles are the same. But the brakes could be different measure them. the mustangs did come with 2 different size brake setups. I know most have never seen it, but I do have a set that are bigger. I even told the guy at the parts counter one day he was nuts. when I got home and guess what. they were different
uedlose is offline
Old 03-01-2014, 07:42 AM
aode08
aode08's Avatar
Did you do the LS2 swap? or the ls1 chevy swap?
aode08 is offline
Old 03-01-2014, 09:42 AM
uedlose
uedlose's Avatar
HELL NO!!! Bite your tongue the rear swap only. I wouldn't put a Chevy engine in a fing wheelbarrow, well yes I would just to push it off a cliff!!
uedlose is offline
Old 03-01-2014, 09:55 AM
mjr46
mjr46's Avatar
lol........................
mjr46 is offline
Old 03-01-2014, 12:32 PM
Krochus
Krochus's Avatar
It's a 2008 model carbed and cammed aluminum block 5.3 (LC9) from a silverado. Needless to say it runs pretty darn strong. The poor 7.5 with. 4.10 gears and a peg leg doesn't STAND A CHANCE of having anything resembling traction. For your viewing pleasure. Name:  F4A3815A-15AD-40FB-B51C-6AF2641589FB_zpsdnmtpwvu.jpg
On the axle it's a 87 8.8 from a GT parts car I inherited. I just got finished re stacking the LSD with new clutches and one extra fiber (she's tight) . It's a 2.73 rear that I'm regearing to 3.27 it's getting all new seals, bearings, crush sleeve eliminator the works.
Krochus is offline
Old 03-02-2014, 06:57 PM
Krochus
Krochus's Avatar
Back to the original topic. The brakes and the axles were the same in my case. Between the two cars I managed to come up with a pair of serviceable if not great axles.
Krochus is offline
Urambo Tauro
Oil and Oil Related Topics
12-11-2017 07:16 AM
firecoyote
08-28-2015 02:12 PM
Stilz
08-19-2015 06:17 AM
Stilz
08-18-2015 09:40 AM
ding56
08-14-2015 02:40 AM
Quick Reply: Ford 7.5 > 8.8 swap
