Pulley alignment issue
Old 04-19-2014, 08:06 AM
BlackStallion5.0
BlackStallion5.0's Avatar
Default Pulley alignment issue
Hey guys,
Here's what I have going on. I have a trickflow sfi harmonic balancer p/n 19007 installed on my 5.0. I went to install my under drive pulleys and the crank shaft looks to set back from the water pump about the width of one belt rib. It becomes more apparent that it's slightly off when I temporarily put the belt on. I tried just putting the stock pulleys back on and it doesn't change anything.
In doing some research I ruled out that it could be the water pump being too long as I was able to compare it to the old one(ran for three years before the engine was dismantled) and they are the same part number from advance auto.
The only thing left is the balancer in my estimation. Has any one dealt with this particular situation? What can I do to correct the problem? Any ideas are welcome.
BlackStallion5.0 is offline
Old 04-19-2014, 08:38 AM
HACKGT350
HACKGT350's Avatar
put the belt on and take a couple pictures from different angles
HACKGT350 is offline
Old 04-19-2014, 09:43 AM
BlackStallion5.0
Ok I'll try to get them up today
Old 04-19-2014, 01:01 PM
dawson1112
dawson1112's Avatar
The water pump is a back side pully with no ribs so the belt will ride where ever it needs to . As long as it is lined up with the power steering pump you will be fine
dawson1112 is offline
Old 04-26-2014, 07:33 PM
BlackStallion5.0
Hey guys I got the pulleys to line up. I called trickflow and they suggested getting longer bolts and stacking the spacers. Worked perfectly! Thanks for the responses.
robcy
Suspension
10-27-2015 11:14 PM
spdeplayer2
10-24-2015 09:45 AM
FivePointToTheOh
09-29-2015 12:53 PM
gagemcc
09-22-2015 09:43 AM
zachary1988
09-18-2015 11:17 PM
Quick Reply: Pulley alignment issue
