What temperature thermostat do you guys run?
Old 05-30-2014, 08:40 PM
65Raven65
65Raven65's Avatar
Default What temperature thermostat do you guys run?
I have a small coolant leak around the thermostat housing, so I figured while I pull it off to replace the gasket, replace the thermostat while it's apart.
Do you guys run stock temp, or the 160?
65Raven65 is offline
Old 05-30-2014, 08:49 PM
reldla1996
reldla1996's Avatar
Stock is best unless you have issues with overheating and you're trying to increase your margin. Tests I've seen show the 5.0 makes slightly more power around 200 degrees (though they like the intake cold!).
reldla1996 is offline
Old 05-30-2014, 09:57 PM
JPJP
JPJP's Avatar
I recommend running the 180° thermostat. I've run the 160° on a 5.0 years ago and it was overdoing it.
The 5.0 makes its best HP when coolant temp is 160-180° I have read but I don't remember the source.
I am running a 180° thermostat with a 3 row aluminum radiator and supercharged.
JPJP is offline
Old 05-31-2014, 11:45 AM
StalkerGT
StalkerGT's Avatar
I second the 180..that's what I've always ran
StalkerGT is offline
Old 05-31-2014, 01:27 PM
65Raven65
65Raven65's Avatar
Thanks for all the responses, guys.
Old 05-31-2014, 09:13 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
180 is the best for all around performance
mjr46 is offline
Old 06-02-2014, 09:36 PM
aode08
aode08's Avatar
180* and drill a small hole on the thermostat to reduce warm up pressure on your cooling system saving you lots of money later.
aode08 is offline
djbigskrilla
09-20-2022 01:04 AM
ShaneB26154
08-28-2015 04:47 PM
microgt
08-20-2015 07:12 AM
jdphillips73
08-16-2015 04:34 PM
yurizx6r
08-11-2015 07:50 AM
Quick Reply: What temperature thermostat do you guys run?
