Fuel pump 89 5.0
I found the relay that was running fuel pump, it was under drivers seat. All the wire diagrams I've found have only two relays. I got 3 one at EEC pass kick panel, one under seat and one in engine compartment pass side. If I pull relay under seat pump shuts off. I've traced all wires all good. All relays are good. What shuts pump off when fuel pressure builds up. Is it timed or a pressure sensor that tells EEC to shut pump off. I'm at a loss because I can't find wire diagram that matches. It's a 02/89 mustang 5.0 conv. I've looked for two days for diag.
if eec doesn't see a pip signal with in 2 sec of koeo, ecm removes ground to FP relay coil side.......you could have a bad tfi or stator in the dizzy which is where PIP is generated...meaning signal is being sent from dizzy when it shouldn't be to ecm......like possible bad distributor bushing causing reluctor wheel to interfere with stator.....pulling distributor and checking integrity of shaft bushing can verify such.
remove the tfi module from the distributor,autozone has a ford distributor tool for that for like 6 bucks, then have them test the unit,get back with us after that because this situation can get complicated.
schecterplayer
09-23-2015 08:38 AM
