is it possible
Old 10-14-2014, 12:32 PM
  #21
84CopperGT
84CopperGT's Avatar
Originally Posted by rmodel65
and both the 351c and the 351w drop right in. they are both small blocks use the same bellhousing bolt pattern and the same engine mounts. and the heads will even interchange.
other than that they are not close to the same. different oiling system, accessories and a few other things.
84CopperGT is offline
Old 10-16-2014, 08:51 AM
  #22
95gtconvert
95gtconvert's Avatar
so a 5.8 out of a 90's model pickup van or bronco will work and I can hook a mustang transmission to it
95gtconvert is offline
Old 10-16-2014, 06:44 PM
  #23
64bit
64bit's Avatar
Holy **** guys... you are all over the place in here.
A 351w is a bolt in swap.
You will need a new balancer (28oz), a new flex plate (28oz), a truck distributor for remote mount TFI, 351w intake manifold, and swap headers, swap oil pan and pickup. The factory 302 fuel rails can be modified to fit.
As for a transmission, you can use your aode after its rebuilt, or... a 4r70w from a 2wd Explorer will fit. Youll need to swap the EPC solenoid, shift solenoid, and TCC solenoid, plus the internal wiring harness and trans fluid temp sensor from your AODE.
As for a computer, your factory 94-95 auto pcm will work, with tuning.
If you don't believe me, ill show you pictures of my 351w/4R70W swapped 94 Cobra, running a tuned W4H0 computer.
64bit is offline
Old 10-16-2014, 07:50 PM
  #24
uedlose
uedlose's Avatar
roflmao bunch of hard heads LOOOOOL I was thinking the same thing LOLOL
Mike he knows what he is talking about.
Ford made 3 351s the Windsor the Cleveland and the Modified. Guys.
But again the 351w will fit where the 302 does and yes you can use the trans from a 302.
uedlose is offline
Old 10-16-2014, 07:57 PM
  #25
bluebeastsrt
bluebeastsrt's Avatar
So your saying..........It'll fit, or no.......
bluebeastsrt is offline
Old 10-16-2014, 08:22 PM
  #26
uedlose
uedlose's Avatar
^^^^^^ LOL
uedlose is offline
Old 10-16-2014, 09:08 PM
  #27
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
please do Kieth..........what no 347 anymore???
mjr46 is offline
Old 10-17-2014, 08:38 AM
  #28
95gtconvert
Thank you this is what I was looking for after I brought up the trans is what all I would need
