Can a 93 dash be made to work in a 86?
Old 01-08-2015, 01:48 PM
TheDirt
TheDirt's Avatar
Default Can a 93 dash be made to work in a 86?
I have a 86 5.0 conv, and just picked up a 93 4cyl parts car,, I'm already using the 93's whole front end, both doors, trunk, all the interior, and complete top and top frame in the 86,,, is there any way to make the dash work?
Thanks
TheDirt is offline
Old 01-08-2015, 02:12 PM
88 orangepeel notch
88 orangepeel notch's Avatar
I don't know the work that is involved, but I have seen a 4 eye with a 87-93 dash at a local car show.
Someone will chime in and give you the details soon.
88 orangepeel notch is offline
Old 01-08-2015, 05:20 PM
DeepImpactPony
DeepImpactPony's Avatar
All Mustangs between 1979 and 1993 are the same, and interchangeable, so long as you have all parts from a donor car, it would be a simple swap.
DeepImpactPony is offline
Old 01-08-2015, 05:33 PM
Boss_Hotrod
Boss_Hotrod's Avatar
I think it would work. May have to change some wiring. The 93 dash will have to be used with the 93 frame also. The 87-89 and 90-93 frames are different due to the addition of the airbag. Id think they would also be different from the 86 frame but not sure.
Boss_Hotrod is offline
Old 01-08-2015, 06:13 PM
84CopperGT
84CopperGT's Avatar
I would think only the steering wheel would be different, maybe the steering column itself, but not the dash frame.
84CopperGT is offline
Old 01-09-2015, 04:55 AM
TheDirt
TheDirt's Avatar
I do have both complete cars, the 86 dash is in bad condition and has wiring issues that's why I'd like to change it,, would it be easier just to swap the 86 drivetrain into the 93?
TheDirt is offline
Old 01-11-2015, 07:43 PM
arnie93lx
arnie93lx's Avatar
Might be the easier way to go, swapping the engine and drivetrain into the 93 4 cyl car and keep the speed density computer but later you can swap to a mass air computer if needed.
arnie93lx is offline
Old 01-14-2015, 06:19 AM
Boss_Hotrod
No, dash frame is different also. The column became a non tilt column for all cars when the airbag came in and of course the steering wheel changed to reflect that. The trim around the gauges changed along with the under column/lower dash trim and the column covers.
djbigskrilla
09-20-2022 01:04 AM
drfister
05-03-2018 10:38 PM
daytooday
05-02-2018 07:22 PM
1st 4 eyed fox
08-15-2015 02:16 AM
dseg
AmericanMuscle.com
08-10-2015 03:29 PM
Quick Reply: Can a 93 dash be made to work in a 86?
