94 mustang gt dies after about 20 minutes. Need to wait until it cools to start it
Old 01-30-2015, 11:21 PM
Mikez90
Mikez90's Avatar
Default 94 mustang gt dies after about 20 minutes. Need to wait until it cools to start it
I have a 94 gt 5spd manual. The car has gt40 upper and lower intake from a 96 explorer, bbk shorty headers, no egr, no smog pump, and no cats, and 3.73s. A month ago I did a complete tune up (cap and rotor, spark plugs and wires, fuel filter, oil and oil filter).
I was on my way home from Florida, the car started dying about every 45 minutes. At first it would start up right away, but then I had to wait for the car to cool down. It was night time, I started checking things and after disconnecting the MAF sensor, I was able to make it home (two hours with the maf disconnected, car didn't turn off).
I bought a new maf but the car keeps dying after about 20 minutes (When the temp hits the middle). It dies violently (it shakes and doesn't die smoothly). I have to wait for the car to cool off before I can start it again. Where should I start? Could it be the fuel pump? Thanks for the help.
Mikez90 is offline
Old 01-31-2015, 06:37 AM
dawson1112
dawson1112's Avatar
The first thing we need to find out is whether the car is loosing fuel or spark.
As soon as it dies and wont restart, check fuel pressure at the rail. And check for spark at one of the plugs.
This sounds much more like an ignition problem, and it could be the coil , the tfi, or the pip inside of the distributor. Electronic ignition parts tend to work properly until they get hot, then once they get hot the resistance goes up and they start to fail. There are some tests you can perform for the coil to check the resistance of the primary and secondary windings, but its too early for me to try to explain it. Google how to check resistance on you coil.
dawson1112 is offline
Old 01-31-2015, 08:07 AM
88 orangepeel notch
88 orangepeel notch's Avatar
And the TFI module can be tested at any local parts store, Auto zone, Advance, etc. Have them run the test 3 times as to build heat, that's when they will fail if bad.
And welcome to the forum.
88 orangepeel notch is offline
Old 01-31-2015, 02:48 PM
Mikez90
Mikez90's Avatar
Ok I will get on that, thank you both.
Mikez90 is offline
Old 02-11-2015, 07:38 AM
HACKGT350
HACKGT350's Avatar
Easy way to check the fuel pump if you don't have a gauge is turn the key and listen to see if it buzzes on for a moment to prime the line.
HACKGT350 is offline
djbigskrilla
09-20-2022 01:04 AM
MEISTERSNFB
03-31-2020 07:50 AM
Philhampton1
08-21-2015 12:04 PM
daytooday
08-11-2015 09:22 AM
89blueslug
08-10-2015 07:20 AM
Quick Reply: 94 mustang gt dies after about 20 minutes. Need to wait until it cools to start it
