Roller rocker adjustment question
Old 03-17-2015, 08:21 AM
88 orangepeel notch
88 orangepeel notch's Avatar
That's not plugged, its a broken bolt.
You could try a drill and easy-out, but you have to be careful. It looks like they bottomed the bolt out on those threads which means its not going to come out easy.
88 orangepeel notch is offline
Old 03-17-2015, 08:47 AM
yurizx6r
yurizx6r's Avatar
That's what I was afraid of. Of course I notice this AFTER I put the heads in.
yurizx6r is offline
Old 03-17-2015, 09:51 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
looks like someone goobered it up in an attempt to try and get it out??
mjr46 is offline
Old 03-17-2015, 09:54 AM
yurizx6r
yurizx6r's Avatar
Probably. Serves me right. I'm going to try heating it up, PB blaster, and tapping it one more time, but if that does not work .... easy out. If the easy out does not work, I call the tig welder guy. If he fails. I'll fill it and make a new hole. Either way it will work. I would just REALLY like to not have to drill it because there is a valve right behind that hole. If that wall gets penetrated.... I need a new head and I'm f'd.
yurizx6r is offline
Old 03-17-2015, 01:04 PM
yurizx6r
yurizx6r's Avatar
On a happier note, everything else is going well. The engine bay is looking great. I wanted to show you guys how it came out since you talked me off the ledge from painting it a few months ago with the motor completely intact. Wow that would have been a mistake. It was challenging enough with it down to the block, but do-able. The first picture was taken just before I started this project. The other is just after I put the heads on. I'll show you guys more pictures when I'm done.
Attached Thumbnails Roller rocker adjustment question-img_20150303_200634.jpg   Roller rocker adjustment question-img_20150315_155542.jpg
yurizx6r is offline
Old 03-17-2015, 05:51 PM
yurizx6r
yurizx6r's Avatar
Yeah baby!!!! Not going to lie........ I was sweating a little.
Attached Thumbnails Roller rocker adjustment question-img_20150317_174811.jpg   Roller rocker adjustment question-img_20150317_174803.jpg
yurizx6r is offline
GPR
12-16-2015 12:21 PM
uedlose
09-30-2015 08:01 AM
Daddys Girls GTs
09-14-2015 08:46 PM
DoctorScary
09-09-2015 07:53 AM
raleigh05GTO
09-04-2015 07:09 AM
Quick Reply: Roller rocker adjustment question
