Block deck and straightedge question
Old 04-27-2015, 07:29 PM
  #71
yurizx6r
yurizx6r's Avatar
Ok I did the boost leak test. With the PCV hose (on the throttle body to the valve cover) on I could not build more than 2 psi at first. Then I found a slight leak on the passenger side header and valve cover. Then it started to build to 3 psi, but nothing more. I then took the hose off and plugged it with my thumb. It went straight to 10 psi then I took stopped because I didn't want any more than 10 psi. I found a very very small leak in the brake booster and a/c hose on the vacuum tree, but nothing to the point where I would say that it would cause such radical behavior that I was experiencing. I'm going to try starting it and doing a base idle reset tomorrow. Damn skeeters are vicious this year.
yurizx6r is offline
mtgldr
02-03-2024 09:00 PM
EASTIDEE123
09-15-2015 11:08 AM
rdog69t
SVT Forums
09-13-2015 06:16 PM
96stang3.8
09-10-2015 06:42 AM
09-08-2015 05:21 PM
Quick Reply: Block deck and straightedge question
