Ran a KOEO test and got a few codes
Ran the test and got codes 34, 81 and 82. Not sure exactly sure what they mean. Any help appreciated. I am having a problem at wot with it breaking up. Not sure if these codes have any thing to do with it
egr position sensor fault,
secondary air diverter circuit failure
secondary air bypass circuit failure.
Just smog related stuff , all normal codes if you have deleted smog and egr.
WOT break up could be a number of things, but some things that come to mind are
Coil
fuel pressure
tps maybe.
Coil
fuel pressure
tps maybe.
All my emissions have been removed but egr is still there...fuel pressure is perfect. Swapped out tps and did a base idle reset and still same problem. Coil is fairly new but it's under warranty so I will replace it anyways. I was kinda leaning towards the pickup coil or distributor itself?
stangin1996gt
09-21-2015 11:01 AM
TfcCDR
09-14-2015 12:08 PM
