EFI to CARB conversion problem, running like a PIG..vacuum problem?
Old 08-28-2015, 08:38 PM
dawson1112
dawson1112's Avatar
Disregaurd that lol it goes into the intake vacuum someplace. I wouldn't run it to the carb. You need to hook it to the tree.
dawson1112 is offline
Old 08-28-2015, 08:44 PM
YoungStangsMan
YoungStangsMan's Avatar
If it helps you any I linked the Carb diagram from edelbrock in my original post which shows the vacuum lines.
YoungStangsMan is offline
Old 08-28-2015, 08:49 PM
dawson1112
dawson1112's Avatar
You can hook it up there, that's essentially the same as hooking it to the manifold or the tree. For some reason I was thinking it should be timed vacuum but its not. So long as its a 3/8 vacuum to the intake.
Old 08-28-2015, 09:05 PM
AK_Kayaker
AK_Kayaker's Avatar
Yes use the one on the carb, that the picture diagram lists for PCV.
AK_Kayaker is offline
Old 08-28-2015, 09:17 PM
YoungStangsMan
Okay thanks I'll give that a shot
Old 09-05-2015, 07:01 PM
YoungStangsMan
Default Update!
Replaced the gas line that was cracked and leaking. Started it up and the pressure's fluctuating from 2-3lbs up and down. Tried to adjust the regulator by loosening the locknut and screwing the allen head bold but nothing changed in pressure... Seems like I might have a leak somewhere still, don't know why the pressure wont raise. Any ideas???
I also tried unplugging the 3/8 inch hose from the vacuum tree (the one going to the carb), and tee-ing it off so I could attach the PCV valve. So basically the PCV valve, and the Vacuum tree are both linked & attached to the PCV connection on the CARB. After starting it up with this configuration my brake booster didn't seem to be working right and it kind of sputtered when I hit the gas.
Still haven't been able to check timing but will this weekend.
Gary Ugarek
63
12-11-2015 02:01 PM
5.0pntydrpr
08-27-2015 10:26 PM
jjwinel78
08-17-2015 03:34 PM
89blueslug
08-10-2015 07:20 AM
Jacob4589
08-08-2015 11:00 AM
Quick Reply: EFI to CARB conversion problem, running like a PIG..vacuum problem?
