Tick tick no start help!!!!
Old 11-24-2015, 11:39 PM
  #21
Jly154
Jly154's Avatar
Oh well the way I figure it this way the stuff I replace I won't have to worry about for a while but it's sure be nice if I could drive er before it snows again in a couple days lol I'll have to try that in the morning when I get off thanks for your help I appreciate it
Jly154 is offline
Old 11-25-2015, 09:52 AM
  #22
Jly154
Jly154's Avatar
So I was thinking to a while back when I had this same issue with my 95 f250 I had to replace the ignition control module could this maybe be what is causing my crank no start condition and If it is where would it be located all I can find is stuff on the constant control relay module does my car not have an ICM and a ccrm instead?
Jly154 is offline
Old 11-25-2015, 11:05 AM
  #23
Chromeshadow
Chromeshadow's Avatar
At this point, what I would do is squirt some starting fluid in the intake and see if it will start and run for a second or two on that. If so, you definitely have a fuel delivery issue.
This is a very easy way to tell if it's an ignition problem or not getting fuel. If it doesn't start for a few seconds with this trick, you should focus on the ignition.
Chromeshadow is offline
Old 11-25-2015, 12:08 PM
  #24
Jly154
Jly154's Avatar
Ok so I know for sure that I have no fuel pressure the little thing that looks like a valve stem coming off the fuel rail has nothing at all coming out now yesterday it dribbled out but nothing now I still don't know yet for sure if it's just the fuel or both I'll have to run to Vatozone to get some ether and I'll give that a try thank you for your input
Jly154 is offline
Old 11-25-2015, 05:56 PM
  #25
Jly154
Jly154's Avatar
Update so I tried some starting fluid and as I thought I don't have any spark at all either along with no fuel could the CCRM be causing this? Or just happen to have that something like coil and fp quit on me?
Jly154 is offline
Old 11-27-2015, 05:00 PM
  #26
Jly154
Jly154's Avatar
Anybody?
Jly154 is offline
Old 11-27-2015, 06:11 PM
  #27
Chromeshadow
I'd check them separately, I'd start by making sure the fuel pump has Voltage. If there is no voltage to the pump, I'd wire it right to the battery and see if you get fuel. If the pump runs when you put 12 V on it, the pump is OK. If the car starts then, the ignition is OK. Might be a good idea to check the fuel filter to make sure it's OK
Old 11-27-2015, 06:57 PM
  #28
Urambo Tauro
Urambo Tauro's Avatar
So it sounds like you have both a fuel pressure problem and a spark problem. Very odd for both to act up at the same time. Looking back at the earlier posts in this thread, this caught my eye:
Originally Posted by Jly154
...do these cars by chance need a transponder key? When I bought it like three weeks ago on my way home with it it stated dinging like a door dinger so I got ahold of previous owner and he said it was because the key that I have is not a transponder key and it's supposed to have one.
Maybe we need to give this possibility a closer look? I've never had to deal with the PATS system, as my car doesn't have this transponder key setup. Hopefully someone more knowledgeable than I will chime in soon. At any rate, your car's previous owner seems to have suspicions about it...
Is your THEFT light doing anything?
Urambo Tauro is offline
Old 11-27-2015, 07:51 PM
  #29
Jly154
Jly154's Avatar
Well that was my fist thought was maybe a security system but then when I replaced the ground wire from battery to block I figured it fried something
Jly154 is offline
Old 11-28-2015, 09:21 PM
  #30
Jly154
Jly154's Avatar
So today I tried starting it today first with the SPOUT in and no spark then with the SPOUT unplugged and I got a spark anybody have any thoughts on this?
Jly154 is offline
Quick Reply: Tick tick no start help!!!!
