custom sub box...
Old 01-26-2006, 09:53 PM
im_stuck_in_iraq
im_stuck_in_iraq's Avatar
Default custom sub box...
Does anybody know where i can get a box for my two 12" subs?? I cant seem to find one..and the box i have now wont fit...thanks..
im_stuck_in_iraq is offline
Old 01-26-2006, 10:05 PM
BlackSVTsnake302
BlackSVTsnake302's Avatar
Default RE: custom sub box...
Try and find a local car audio shop, I live in Wisconsin and theres a place down the street called Xplosive Audio, they do all kinds of installs, custom boxes, all kinda of cool stuff...
BlackSVTsnake302 is offline
Old 01-26-2006, 10:11 PM
im_stuck_in_iraq
where at in wisconsin?? ill be there in a week...i am going on leave...
Old 01-26-2006, 11:13 PM
gt96stang
gt96stang's Avatar
Yeah, you need a box specifically made for those subs, Those cheap boxes will make your system sound like crap.
gt96stang is offline
Old 01-26-2006, 11:29 PM
im_stuck_in_iraq
thanks..
Old 01-29-2006, 03:39 AM
BGM66
BGM66's Avatar
crutchfield has boxes to fit in mustang trunks, if I had subs, i would definately go for that.. got to crutchfield.com and seach for it.
BGM66 is offline
Old 01-29-2006, 03:41 AM
BlackSVTsnake302
Appleton wisconsin
Old 01-29-2006, 03:47 AM
Black Snake
Black Snake's Avatar
You cant just throw any custom made box in your trunk, theres a couple of things that needs to be done.
Alot of mesuring is required, not just the fitment of the box but on certain subs you need a certain amount of air space or volume. The right amount of air space is needed for your subs to sound right.
For instance my friend baught a set of 10" JL Audio w7s and threw them in a already made box. I installed the same speakers and amp in a Merceeez with the right sized volume box. The sound is 10x better with the better box.
Black Snake is offline
Old 01-30-2006, 12:22 AM
Lazlo
Lazlo's Avatar
Unless your after a show type fiberglass setup I'd just make one yourself. Car audio shops generally charge way too much IMO. You definitely don't want to buy a generic one, a great sounding system is 25% equipment, 75% install. If you buy a sheet of 3/4" MDF frome home depot they will cut it for free, they just won't do angles, the holes, or small pieces. If you stick with a sealed rectangle all you have to do is measure, cut the holes for the subs, and put it together. Most subs come with plan sheets telling you the optimum volume for the sub, some even give you measurements for ported boxes. If you want post up what subs/amp you have, measurements of your trunk, and what you want from the system and I'll make you a plan to follow.
Lazlo is offline
Vrooom
02-21-2016 05:25 PM
mdg
10-01-2015 07:04 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-01-2015 08:16 PM
Quick Reply: custom sub box...
