AC pump and belt
Old 02-02-2004, 05:52 PM
mkspeed26
mkspeed26's Avatar
Default AC pump and belt
i would either get the ac eliminator kit or get a shorter belt. if you go with the shorter belt just make sure that you get it to the right size
mkspeed26 is offline
Old 02-02-2004, 07:20 PM
Quik
Quik's Avatar
the easiest f***ing way to to remove the pump. you dont need that f***ing thing turning if you dont have the rest of the components. have fun trying to get the right belt without the kit. the FRPP moves the power steering pump up where the ac was. then go to the store and with no measuring tell the clerk that you need a belt for a AC delete mustang 5.0. and they will give you a perfect fit belt.
if you get the kit. ill tell you the part number you need for the belt.
Quik is offline
Old 02-02-2004, 07:42 PM
Milky
Milky's Avatar
I dont know if i want the sterring pump up there, i want that extra bit of room up top. Where can I get the different bracket? The belt can't be that tough to measure for as long as it clears. btw how much play is there supposed to be in the belt? 1/2 inch?
Milky is offline
Old 02-02-2004, 09:23 PM
primetime5.0
primetime5.0's Avatar
i had a march ac eliminator and i didnt like it it would throw belts and shred them to pieces thats why i recomended the ford racing eliminator, as for the belt size life the tensior up as high as you can go just to make sure they'll be enough clearance... and from personal experince bypass the smog pump!
primetime5.0 is offline
Old 02-02-2004, 10:03 PM
n2o44
n2o44's Avatar
</P>
easythere hot shot , lol , </P>
n2o44 is offline
Old 02-03-2004, 10:37 PM
pacepony
pacepony's Avatar
do they make a ac eliminator kit for a 79 mustang, if so where can i get one
pacepony is offline
Old 02-03-2004, 11:17 PM
gorbs88
gorbs88's Avatar
Why dont you just put hte power steering up there???????Seriosly why pay money for the ac eliminator when you can do it for free???Thats what i did....Thats where it is factory so it wont be in the way...If you run with the air pump then you can go buy a belt, but if you get rid of air pump then you will have to measure it...
gorbs88 is offline
Old 02-04-2004, 01:55 AM
Quik
Quik's Avatar
the FRPP ac elimnator is a bracket that is factory from ford. that you use to mount the power steering pump up where the AC used to be. it bolts to the head and water pump.
Quik is offline
Old 02-04-2004, 01:13 PM
gorbs88
gorbs88's Avatar
Ohhh, ok....wasnt to sure about that, All my point was to go to a wreckin yark and you could get the bracket for like 5 bux.....some people buy a idler for the place of the ac... i think that is useless....Well thanx for the info on the frpp eliminator.....
gorbs88 is offline
Old 02-04-2004, 02:21 PM
Quik
Quik's Avatar
no prob. he could go to he savage yard. and try to find one but it is actually rare to see a stang without it. but good luck the kit is only like 40bucks. i think maybe less maybe more. been awhile since i bought mine
Quik is offline
jwog666
12-27-2021 08:09 PM
Bokeo
10-10-2015 08:28 PM
1996cobraconvertible
SVT Forums
09-30-2015 02:01 PM
mrappe
09-26-2015 10:16 AM
Quick Reply: AC pump and belt
