Winter projects...
Winter projects...
I've been waiting awhile for this thead, so screw, I'm gonna start it.
I've got plenty on my plate this winter...
3g alternator swap
March Alternator bracket/tensioner delete
AIR pump delete
BeCool aluminum radiator
Lincoln Mark VIII electric fan
Dakota Digital fan controller (dcc won't respond to emails...)
Solid Aluminum tranny cross member bushings
Prothane tranny mount
Correct ARP stainless 6 pnt header bolts to replace my 12 pnts
MM full length XL subframes
Battle Boxes
Adjustable pinion subber
Driveshaft safety hoop
Tilt column swap
Alarm install (had one before, so the wiring is already chopped)
iPod controller for my deck.
8" subs in doors
5.25" MB Quarts in kick panels
Adcom GFA-4404 to run the highs, keeping my Audio Art 50HC and cheap 12s in the hatch for this year.
I also just bought SN-95 spindles and brakes... I doubt that I'll be able to afford the rest of the 5 lug this winter, but it still exists..
All that is in addition to my late summer plan of ported/polished GT-40 heads, matched Cobra intake, and bumpstick... She should be coming along nicely come September...
So... What are YOUR plans this winter?
3g alternator swap
AIR pump delete
Battle Boxes
Tilt column swap
8" subs in doors
RE: Winter projects...
mine was a trans go shift kit, and upr front drag suspension but now im done so im looking for more parts to put on....:Probably an 8 point, subframes, weld the torq boxes,and a 5 point harness
Already bought and waiting to go on the car:
Subframe Connectors
Upper and Lower Rear Control Arms
Re-enforcing torque boxes
CAI
MAF 75mm
TB 70mm
Intake elbow
GT 40 intake upper and lower
ZEX 100 Dry shot
New plugs
New front rotors and pads
Maybe:
Drag radials
GT-40 heads
cam
Swarr bar
Subframe Connectors
CAI
MAF 75mm
TB 70mm
Intake elbow
ZEX 100 Dry shot
New plugs
Maybe:
Drag radials
GT-40 heads
cam
Swarr bar
This winter I want to install
3.73 gears
31 spline diff.
31 spline axles
and nowfix my ashtray
thats all I can think of now. winters are weak down here, so I don't really have to park it long, only when its rainy
3.73 gears
31 spline diff.
31 spline axles
I dont have too much planned for the winter.
all the t-top weatherstripping
possibly 3.73's
exhaust (still undecided as to the specifics)
and finally get around to finding and fixing this coolant leak thats been bugging me.
possibly 3.73's
AFR165's - Pending
Comp Cam - Pending
Rear Main Seal - Done
Alumin Driveshaft - Done
Driveshaft safety hoop - Done
MGW Shifter - Pending
Summit Ignition Box - Pending
Sub Frames - Done
My project is commin along nicely but spring is commin fast
Comp Cam - Pending
Sub Frames - Done
