Cleaveland vs windsor (heads)
Old 10-24-2009, 01:58 AM
marlyman
marlyman's Avatar
Default Cleaveland vs windsor (heads)
I was told that only one of the two are compatable with the stock 302 out of a 87-93 mustang and i see sum 351W heads for kinda cheap on ebay and i heard that using the 351 heads makes a huge difference so just curious do they both work or only one and if so which one would work on my 302?
marlyman is offline
Old 10-24-2009, 02:55 AM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
A 302 and a 351w are basicly the same thing. 351's have a taller deck height causing them to be wider so things like the oil pan, acc brackets and the intake will be different. The heads will work but you need a set of bushings or step down head bolts to bring the 1/2 head bolt hole of the 351 head to the 7/16 head bolts a 302 use. 351 heads can make for better performance but you want to find a set of c9 or d0 heads (69/70) because of the smaller CC and bigger valves.
projectresto83 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
bradleyb
11-27-2015 07:50 PM
kevsgt
10-09-2015 10:12 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Drastang
09-30-2015 03:48 AM
Quick Reply: Cleaveland vs windsor (heads)
