SCT 4 bank eliminator, worth it???
My car currently has minimal mods like custom exhaust with FLows 40, K&N drop-in filter, MSD cap and rotor, 9mm Ford racing spark wires and 3.73 rearend. I'm planning on put in a C&L 73mm MAF 19lbs. and a BBK 65mm throttle and EGR spacer. My question is, its worth throwing in a SCT 4bank eliminator with my setup?
Any advice?
Any advice?
i have a sn95 maf on mine right now. it's a 70mm for 19's.with the cai and maf it made a huge diffrence.i had heads and cam on first though.i'm changing my set up now,i knew i would so that's why i went with sn95 cause it was cheaper and don't feel bad having it sitting on the shelf now.but first thing you should do is change your fuel pump.
I have a 95 5.0. I installed a cobra upper and lower with BBK CAI, 70mm TB, 80mm MAF, 24# injectiors, underdrive pulleys, bbk tuned length headers. The parts were easy as hell to install and relatively cheap in the first place. The car definately woke up. I can't believe the diffenece. I have a SCT 4 bank eliminator that I will be getting tuned here in a bit. I'll let you know how it goes and if I feel any big difference. I have to say though, eadvancing your timing is by far the cheapest hp gain out there.
