17x9's up front
Old 03-08-2010, 07:09 PM
tohoopty
tohoopty's Avatar
Default 17x9's up front
im wanting to get some 17x9 03 cobra wheels but am wondering if they will rub the struts up front any.i also have 4cyl spindles and brakes up front
tohoopty is offline
Old 03-08-2010, 08:08 PM
ALMOST STOCK
ALMOST STOCK's Avatar
It seems that if there is any rubbing at all with 17X9 in the front its the rim on the A-arm, which is a easy and cheap fix. Rack limiters/Travel restrictors there both the same part.
I have 17X9 in front and that was the only problem I had!
ALMOST STOCK is offline
Old 03-08-2010, 09:00 PM
LiL3viL
LiL3viL's Avatar
im lowered 2" in front with 17x9 cobra r's on 225 tires and my wheels rub on my a-arms. easy fix as stated before though.
LiL3viL is offline
Old 03-08-2010, 09:35 PM
tohoopty
tohoopty's Avatar
i just wanted to make sure.i didnt want to drop money on rims and they rub the struts.i dont care if they rub the a arms and i dont ever turn my wheels all the way anyway.i already got the v8 spindles if i need to change them so thats no big deal
tohoopty is offline
Old 03-09-2010, 01:44 AM
nacanitihs
nacanitihs's Avatar
i run a 245/45/17 yokohama on the front with my 17x9 cobras. like stated they rub the a-arm at full lock but i just dont turn it full lock. also you may have to push the inner fender well plastic up and use a short self tapping screw to hold it. mine started to eat through the plastic. but thats easy
nacanitihs is offline
Old 03-09-2010, 09:46 AM
tohoopty
tohoopty's Avatar
im not worried about those rubbing problems as long as it dont rub anything while rollin straight.
tohoopty is offline
Old 03-09-2010, 11:20 AM
nacanitihs
nacanitihs's Avatar
nope you should be good to go then
winner99
10-01-2015 01:06 PM
winner99
10-01-2015 10:52 AM
mdg
10-01-2015 07:04 AM
UrS4
09-30-2015 10:13 AM
marc954
09-29-2015 11:18 AM
Quick Reply: 17x9's up front
