Need suggestions on what heads and supporting parts for 347
Old 05-27-2010, 09:59 PM
Js04sILVerBullet
Js04sILVerBullet's Avatar
Default Need suggestions on what heads and supporting parts for 347
Buddy of mine has 347 short block that he is running a carb setup on.THis is pretty much a street/strip car that is not meant to be a dd.lol
He already has
-Holley 750 carb
-Edelbrock victor jr intake manifold
-Custom grind hydrolic roller cam ~ 233*/243* .576/576 w I-6 111 lobe sep.
What size heads would you guys reccomend he run with this setup?which rocker arms and valve springs as well?
thanks in advance
Js04sILVerBullet is offline
Old 05-27-2010, 10:20 PM
67mustang302
67mustang302's Avatar
TFS FAC 190 would be a good head with that setup. Good power with a good price.
And why isn't that a daily driver? It's hardly what I'd consider wild, and seems like it would be well under what many people would consider the limit of streetability.
67mustang302 is offline
Old 05-28-2010, 12:33 AM
socalwrench
socalwrench's Avatar
190cc to 200cc runners would be great. Choose a combustion chamber size that keeps his overall compression ratio where he wants it. For valvesprings, I would recommend whatever the cam grinder does. Comp Cams makes good stuff, as does Crane Cams. I particularly like the Ford Racing roller rockers, but the Crane Cams ones work just as well. If you really have some money to spend on rockers, check out Harland Sharp http://www.harlandsharp.com/
socalwrench is offline
Old 05-28-2010, 06:50 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
this is tech not suggestion section....moved!!
https://mustangforums.com/forum/5-0l...bers-read.html
mjr46 is offline
Old 05-28-2010, 06:55 AM
AdderMk2
Banned
AdderMk2's Avatar
so far the advice here has been pretty good. Like said above, any good 190-200cc head will work (not procomps).
My concern is that carb. Your buddy may find that to be a bit on the small side.
AdderMk2 is offline
Old 05-28-2010, 01:14 PM
Js04sILVerBullet
I apoligize.I will be more careful next time I post
he got a pretty good deal on the carb so we are figuring we will try it and go from there.We just weren't sure what size head would fit it nicely.
Thanks to everyone for the response's.
Old 05-28-2010, 09:19 PM
tinman
tinman's Avatar
Stay away from 'Pro-Comp' heads........
That 750 carb maybe all you need with a decent head.
I'm running altitude corrected 10.90's with a 3.40 stroke engine on a 650D.P.
Somewhat larger cam than what you have and 195cc TF 'TW' heads that are cnc'ed
tinman is offline
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
cbird1177711
09-03-2015 08:43 PM
Steve@CJPP
CJ Pony Parts
09-03-2015 11:43 AM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: Need suggestions on what heads and supporting parts for 347
