astro performance transmissions?
Old 06-10-2010, 08:18 PM
dillon1340
dillon1340's Avatar
Default astro performance transmissions?
my third wc t-5 just blew out again. i'm not going with a stock rebuild again. anyone ever use astro's transmissions?
dillon1340 is offline
Old 06-11-2010, 03:58 AM
67mustang302
67mustang302's Avatar
What have you done to the car? If you keep blowing up transmissions it could be you, and not the trans.
67mustang302 is offline
Old 06-11-2010, 12:42 PM
94ford5liter
94ford5liter's Avatar
I have heard good things about their T-5s. They are supposedly pretty good quality. However, if you want a much stronger replacement transmission for cheap, you can get tr3650s on Ebay for under one thousand dollars all day. Then all you need is a different bell-housing, clutch, and transmission cross-member or you can modify the stock one.
94ford5liter is offline
Old 06-11-2010, 09:32 PM
dillon1340
dillon1340's Avatar
i have done very little to the car besides chassis work; it still has stock power. in fact i hardly drive it at all. however i have had horrible luck with t5's they keep shattering 2nd gear. i don't drive too aggressively, not enough that i should keep breaking them.
Old 06-11-2010, 09:35 PM
nba1341
nba1341's Avatar
are you fast in the furious redlining your transmissions?
nba1341 is offline
Old 06-11-2010, 09:42 PM
nitrous_bob
nitrous_bob's Avatar
check out the "super alloy gearset" from d&d
http://www.ddperformance.com
nitrous_bob is offline
Old 06-12-2010, 08:05 AM
dillon1340
dillon1340's Avatar
yeah i was looking at the tko's on d&d's website. i think in the end i'm going to go with a gforce t5.
Old 06-12-2010, 10:30 AM
TrimDrip
FudgeDrip
TrimDrip's Avatar
I know a guy with one built with astro performance parts. Seems to do good with 500lbs. of torque so far. He did break a shift fork but, the guy that did the installing lied to him about putting the stronger forks in and kept his good shift forks.
TrimDrip is offline
Old 06-12-2010, 01:30 PM
67mustang302
An upgraded T5 is quite strong, GeForce, Astro etc. Protmotion Powertrain in Fl builds some also, using GeForce gearsets I believe. However, if you keep frying second gear with stock power, then you should probably work on your shifting/clutch skills. Do you have a clutch that grabs super fast and hard? Or are you letting the clutch out really fast after you shift? Even a heavy aftermarket upgrade can break if you abuse it, and there's no sense in spending all the dough on it and breaking a high dollar trans too.
If it makes you feel better, I previously ran a Toploader and now a TKO600 in my 67, so I don't have to worry too much about abuse. But I still shift properly as there's no sense in abusing something that doesn't need it.
Old 06-12-2010, 02:43 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
your definition of driving aggressively vs mine, gauranteed don't coincide with one another, if you shatter 2nd, lay off the power shifting, 2nd doesn't just shatter from driving it normal......I've run 10 sec passes on stock t-5's, it's all in how you handle them
mjr46 is offline
Quick Reply: astro performance transmissions?
