Spark plug gap with boost
Old 06-16-2010, 07:31 PM
g3mustang
g3mustang's Avatar
Default Spark plug gap with boost
I have a set of autolight 24. I gaped them at 32... I am puting in my s/c in a couple days so I wanted to put in my plugs now before I start the s/c install... After I put them in a started the car and my idle is searching... Is the gap to small with out the s/c installed??? It sounds like all are fireing.. Checked all connects seems ok... Any ideas
Thanks
g3mustang is offline
Old 06-16-2010, 07:45 PM
nitrous_bob
nitrous_bob's Avatar
.032 is awfully conservative.
i spray 80-100 and gap .042" on stock coppers
but i doubt that you would have driveability issues. i would check your plug to plug wire connection... if it doesnt "snap" its not on
also double check firing order
nitrous_bob is offline
Old 06-16-2010, 07:54 PM
g3mustang
g3mustang's Avatar
It revs fine and I did one plug wire at a time... It does smell alittle more rich
Old 06-16-2010, 11:16 PM
67mustang302
67mustang302's Avatar
That is a small gap. I'm n/a and run my gap at .055 and it will probably tolerate more. Try like .040 and see what it does, if it misfires at higher rpm and/or under higher boost then the gap is too big.
67mustang302 is offline
Old 06-17-2010, 09:33 PM
NoGo95GT
NoGo95GT's Avatar
When you install the supercharger I would change the gap to .028-.030. I have mine set to .025 on Autolite 3924's. But I am also running much more boost. I end up replacing them twice a year.
NoGo95GT is offline
Old 06-17-2010, 10:43 PM
luckythirteen13
luckythirteen13's Avatar
i run a 32 gap on mine with 11psi. i dont plan to change the gap when i go to 15psi
luckythirteen13 is offline
Old 06-17-2010, 11:16 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
.032 should be fine. Are you sure you didn't create a vacuum leak? I would run the codes to see what is going on.
TrimDrip is offline
Old 06-18-2010, 02:16 PM
g3mustang
g3mustang's Avatar
so i gaped the plugs at .042 and installed my supercharger!!!!!
after driving the car for a while and after reaches operating temps im having a surge... belt is not slipping.... cruising im fine... go full throttle and every once in awhile it feels like a miss. or feels like the supercharger belt is slipping but i ahve a boost gauge and its not.. maybe something is getting heat soaked... maybe the gap in the plugs is too big now.
only running 5psi
any thoughts
Old 06-18-2010, 02:46 PM
67mustang302
Try going to .035 and see if it gets any better.
Also, what do you have for an ignition system? Have you made changes to the fuel system to accommodate the blower?
Old 06-18-2010, 03:04 PM
g3mustang
g3mustang's Avatar
stock ignition[msd coil, cap,and rotor]
just using the fmu it came with
Quick Reply: Spark plug gap with boost
