brake problems... need advice :(
Yeah, adder is right.
Personally anytime I have had a problem like this, it has been a bad master or I bled just a little too much and ran out of fluid in the master pushing air through the lines.
It wouldn't hurt if you jacked the rear while bleeding them either.
lol ok, well from what i can tell my problems are all in the front of the system. I have blocked off the front system from the rears, and i have gotten a FULL pedal rock solid along with NOT being able to rotate the axles with the car in nuetral
Those valves are all on the rear system lines
Once again, I would loosen the line a little on the master for the front brakes and have someone press it to the floor and hold it while I tightened. It should shoot out of there like crazy. It won't put massive amounts of air in the lines and will tell you if the master is bad. Then I would look at getting it at the calipers, hoses and so on. Just don't get the fluid on the paint.
I have changed a many of masters like this and never once loosen a bleeder on the brakes.
if you are getting fluid like you say at the lines......you should have brakes
If the wrench is on the bleeder at the bottom side of the caliper on the second pic of your first post, I will make fun of you for a long time for not being able to bleed them. That is what it looks like but, surley it isn't.
Matt's 95 Stang
10-05-2015 07:16 AM
09-25-2015 06:42 PM
